Brake Drums
Old Feb 11, 2006 | 10:31 PM
AgentofDarkness's Avatar
Default Brake Drums
For more than half the day today, i was attempting to install new brake shoes on my car. Long story short, a wheel cylinder and brake line later, i'm done. However, there is one problem. The drum will not fit over the shoes, i've already moved the adjuster so that its at the lowest it can be. Still the drum isn't fitting over the shoes. I was thinking that i should have the drums machined, since it has 100K miles on and there might be a big rust ridge or something. However, the other drums i've done haven't had this problem, infact i had to turn the adjuster so that the pads would strech out a little more to touch the drums. But this is the first honda i've done. Any help would be appreciated, i gotta get this done by tommorow since my dad needs the car on monday and i still have to do the left side.
Old Mar 4, 2006 | 08:07 AM
yorky's Avatar
Default RE: Brake Drums
that happened to me when i was doing my brakes.set the adjuster so the drum will fit then you can adjust the starwheel from a hole on the back side to make the shoes fit. If not beat it on with a hammer,drums can take some abuse.
sfazngiants
Jan 2, 2008 10:05 PM
rit14623
Nov 27, 2007 09:13 PM
blink21me
Mar 5, 2007 12:10 PM
civicexracer
Mar 27, 2006 01:35 AM
Pete
Apr 18, 2005 09:58 AM
