Caliper pin frozen??
Old Jan 4, 2010 | 11:57 AM
teqmod's Avatar
Default Caliper pin frozen??
I was having a strange issue with the rt front and left rear brakes not applying. After thinking it was a failed M/C and bleeding the brakes I noticed the inner pad on the rt side caliper was not toucking the rotor and could see it move to engage the rotor then pull back. This explains the horrible pedal and lack of pedal. I removed the lower bolt and was able to rotate the caliper up with little resistance. I pulle the LT side and was able to rotate it up as well with no resistance but it does not slide back and forth on the pin on either side. I would think if the pins were seized I would not be able to rotate the caliper up when the lower bolt is removed. Am I missing something? This is a 97 civic.
Old Jan 10, 2010 | 12:20 PM
conceptualpolymer's Avatar
When you rotate, you are allowing the pin to contact just a small surface area, whereas sliding the calipers on pins involves a much larger area. Sticking slides is very common if the pads aren't replaced for many years due to lack of use. Grease up the pins/replace the pads and you should be okay.
Old Jan 10, 2010 | 09:10 PM
Largen's Avatar
If need be, Get some very fine sand paper when you remove the pins and dress the sliders if they have pitting or corrosion. Also when you Grease them use Silicone Grease.
Old Jan 11, 2010 | 12:34 PM
teqmod's Avatar
Problem is they are still frozen on the pins and I can't get the calipers off the pins. Used a BFH and penetrating oil with no success so far. I am hoping I don't need to get new calipers and brackets. The heat wrench may be making an appearance next as a last ditch effort.
Old Jan 11, 2010 | 05:13 PM
Largen's Avatar
Wow, they must be on good holy crap, Try heat if not.. Heat and smack-em with a hammer a little, just dont get to happy with the hammer XD the heat should do it too.. but dont get to happy with that either, remember theres a few components inside the caliper that can melt.
Old Jan 12, 2010 | 05:50 AM
teqmod's Avatar
I soaked em with wd40 for about an hour and then got very liberal with the BFH and they finally came off. I figured either they would come loose or I would have to replace them anyway. Thanks for the input!!
muuurph
Nov 17, 2008 10:54 AM
tgifford5
Aug 19, 2007 05:25 PM
mcmichael13
Feb 19, 2006 07:53 AM
DingR
Dec 14, 2005 09:04 AM
Jack1956
Oct 16, 2005 09:58 AM
