car shakes after new slotted/drilled rotors and new pads
Old Jan 19, 2008 | 06:14 PM
00IntegraLS's Avatar
Default RE: car shakes after new slotted/drilled rotors and new pads
just called the company that sold me them and they said that its a common problem they have because sometimes there is too much zinc on the rotor and after a week or so it should go away.... I have a 90 day warranty so I dont think this guy was talking out of his @$$. he made it seem like it was a common problem that a lot of their customers have and it should go away after a week or so...... does this seem like a legit reason?
Old Jan 19, 2008 | 06:19 PM
Fiirkan's Avatar
ORIGINAL: addiction2bass
did he bleed the brakes also?
sounds like it shouldnt be vibrating unless they are warped or maybe not firmly instaled....
i would definatly have the guy look at them again!
if he cannt come up with anything then swap the wheels back, BUT i dont see them being the problem since you say it vibrates when you hit the brakes....
sounds to me like the rotors are warped... or maybe he forgot to clean the rotors protective coating off and it loaded up the pads.... hard to know...
i guess just depends HOW GOOD of a brand rotors you bought..... some cheap brands i could see them being crapy brand new and shaking like that from not being balanced....
which is why id spend the extra money for a beter brand rotors.
they are just like wheels that need to be balanced but i dont know of any places that balance them.LOL
He replaced the padds and rotors... i think you fail to see this part... cause last time i checked.. last time i did my brakes you don't need to bleed them as the don't have fluid... only the caliper does
also needing to bleed the brakes would not cause them to shudder when braking.
Old Jan 19, 2008 | 06:21 PM
yesterday when i tried installing them myself, i accidentally turned the bleeder screw and liquid drained out and I got an air pocket, so he did have to bleed my brakes.... does this make a difference?
Old Jan 19, 2008 | 06:28 PM
Fiirkan's Avatar
ORIGINAL: 00IntegraLS
well if thats the case lol... as long as it was bled it shouldn't make a difference. best bet would be to take it all off, then put it all back in, 9 out of 10 times that fix'es it right there
Old Jan 19, 2008 | 06:31 PM
Did you happen to get some brake fluid on the pads or rotor? If you did, it also could cause the brakes to stutter.
should I wait off and see if this guys "zinc theory" is correct? give it a week or so and see if it goes away? also, my friend brought me the car after it was done and im sure he didnt break them in properly, could this have heat them up too fast and then caused them to warp?
Old Jan 19, 2008 | 06:32 PM
ORIGINAL: RonJ
personally, I didnt even take the rotors out of the package
Old Jan 20, 2008 | 04:50 AM
well if the company says its a common problem....
then their products must just suck.LOL
i guess just cross your fingers and hope it will go away or minimize then....
what brand are they by the way
Booshanky
Sep 3, 2010 03:19 AM
vitaliy.s
43
Jun 11, 2009 07:33 PM
Chigga!!!!!
EG Swaps
Mar 9, 2007 04:10 PM
importtuner666
Jun 15, 2006 10:10 AM
01CivicEX
13
Mar 28, 2006 07:26 PM
