Creaking noise from control arm...
Old Jun 26, 2007 | 11:49 PM
Everyday Getaway's Avatar
Default Creaking noise from control arm...
I recently installed new suspension on my car, today I realised that there is a creaking sound from what seems to be my left rear control arm. I heard the noise when I told my friend to stop sitting on my trunk, when he got off it creaked, then I pushed down on it a few times and let it spring back up, again I heard the noise, but only when I let it spring all the way up. When I installed the rear suspension I un-bolted the control arms, I don't know if this had anything to do with it, just thought I should mention that. Anyone have any idea if this is a problem... or if I can fix it?
Old Jun 27, 2007 | 11:04 AM
civicexracer's Avatar
Default RE: Creaking noise from control arm...
double check everything on ur suspension, make sure everythings tightened and seated correctly. could be a bushing rubbing somewhere tho im not sure. did u buy the suspension new or used?
Old Jun 27, 2007 | 03:17 PM
DaRKoN's Avatar
Check that the spring is seated properly. It may be moving or twisting when the load is removed
Old Jul 2, 2007 | 02:54 PM
ORIGINAL: DaRKoN
How can I tell if it's resting properly? Also, if it were twisting, wouldn't it eventually rest properlly anyway? Thanks.
burgernuds
Jun 15, 2009 03:58 PM
Hobo
19
Mar 29, 2008 08:04 PM
MOONRAKER
Aug 8, 2006 10:37 AM
dstone3
Jul 3, 2006 04:19 PM
Stimpy
Mar 11, 2006 06:45 PM
