Energy Hyperflex Suspension Kit
Old Nov 27, 2007 | 05:26 PM
jbum's Avatar
Default RE: Energy Hyperflex Suspension Kit
I have a couple of questions. Is it cheaper to buy the master kit than buying the individual packages? I think I wanted more or less all the bushings except for the end links for the swaybar as my car does not have swaybars. If I buy all of them separately except for the swaybar bushings would I end up paying the same amount? I haven't found a site that lists the prices for all of them... if someone can point me to one I'd appreciate it.
Second question... I asked this in another thread but here goes. Instead of burning the bushings on the LCA, can you use a hacksaw and cut up the bushing into pieces to relieve the outward force it exerts on the metal sleeve? Then pound the sleeve out with a socket?
I don't have a torch and I'd rather not burn anything... smoke, dirty, etc.
Old Nov 27, 2007 | 09:02 PM
koots's Avatar
ORIGINAL: jbum
It's cheaper to buy the whole kit. and you should have at least a front sway bar, but you never mentioned the vehicle you had.
you could try hacking up the bushings but they are faiirly resilient to cutting and it would be really hard to get a hacksaw close enough to do some damage. I used a lot of angry brute force to get the bushings out of my truck when i did the full prothane install. i was considering getting a shop to do it, but they quoted me 5 hours for each side of the front suspension, let alone the remaining bushings. so save yourself the money and try it yourself. if you get stuck bring the piece and new bushing to a shop to get them to press-fit it in.
Old Nov 27, 2007 | 09:47 PM
jbum's Avatar
oh my car is a '93 Civic DX 4DR. I'm pretty sure my car doesn't have a sway bar in the front.
Old Nov 28, 2007 | 04:28 AM
mxs's Avatar
mxs
ORIGINAL: jbum
www.energysuspensionparts.com
ORIGINAL: jbum
You want to hack through the inner collar??! It's 1/8" thick steel with a 3/8" hole in the middle. When you burn the rubber, then the inner collar will just fall out.
ORIGINAL: jbum
The sleeve is like bonded to the control arm... you can't knock it out... I have used a hacksaw to cut through it and then pushed it out with an air chisel
ORIGINAL: jbum
If you don't want to get dirty, this project is not for you!
Old Nov 28, 2007 | 10:05 AM
blackmetal619's Avatar
i went to a certified honda place for an estimate.
I told them, mount and balance my rims and tires, front and rear camber kit, springs/shocks, bushings, and aligmnment.
They said $1200 + 50 for alignment.
And that they would do the springs/shocks and camberkits for free, and bushings would be 1200.
Also they said it would take 3 days
bp4131017
Feb 1, 2010 08:00 AM
bp4131017
Aug 15, 2008 10:24 PM
1slowcivic
Apr 10, 2008 08:01 PM
fastman90
Transmission and Differential
17
May 1, 2007 11:31 PM
ohbiskits
Nov 9, 2005 08:41 PM
