Front Rotors replace instructions
Old Nov 1, 2006 | 12:14 AM
lordyrichie's Avatar
Default Front Rotors replace instructions
hi all
i tried to change the front rotors of my dx 97 4 dr vechicle but there are two screws on .the two problems i would like to ask about are the new rotors dont have anyholes for the screws. can i still install the new one and disregard them.and the second thing is do i have to use impact screw driver with a regular hammer.
that is it
thx
Old Nov 1, 2006 | 01:11 AM
Default RE: Front Rotors replace instructions
hmmm ive never seen a rotor without the screw holes. and yes you will need a impact screw driver just be carefull hitting it the screws well they are little bolts with a philips head on them they are easy to break. about the rotors without the holes check with the place you got them at and see if they gave you the right ones good luck
Old Nov 1, 2006 | 02:17 AM
psychocivic's Avatar
you need the holes on the rotors. those 2 screw/bolts hold the rotors in place. and yes be careful with taking them off, they strip really easy. use plenty of wd-40 or something. good luck.
Old Nov 1, 2006 | 06:56 AM
mxs's Avatar
mxs
you don't NEED them. it just makes it easier to put everything back together. Lug nuts hold it in place.
Old Nov 1, 2006 | 08:36 AM
Misha's Avatar
ORIGINAL: mxs
+1
It does not hurt if they are there. If they are not, does not hurt either
Old Nov 1, 2006 | 11:21 AM
Pete's Avatar
I stripped mine and then just drilled thru em. You dont need em, they are there to hold the rotors on the car when its on the assembly line. As MXS Said, the lugnuts hold the rotors on, not those 2 puny screws.
Old Nov 1, 2006 | 03:56 PM
thx everybody
this web site rocksss
Old Nov 1, 2006 | 05:40 PM
Mark's Avatar
As said before the screws just hold the disc on when its going down the line. I recommend anyone with a new civic to take the screws out while you still can. A few years down the road when you need to do your brakes its gonna be a bitch to get those out.
Old Nov 8, 2006 | 01:13 PM
i just wanna inform you guys that i installed the new rotors and pads.they work perfectly fine i just had to bleed the system in order to get the mazimum braking power.
thx again for ur help
Booshanky
Sep 3, 2010 03:19 AM
peige414
Jan 8, 2008 04:07 PM
theredsuit
18
Aug 9, 2007 04:48 PM
mchiles
Apr 26, 2005 08:18 AM
StifflersMom
Jan 25, 2005 04:34 PM
