Help!!!! i can't get the lower tie Bar on
hey guys i tried installing the lower tie bar on a honda civic and just when i removed the bolt the whole bar moved so that the hole is not aligned... what should i DO??
get the holes lined up till u see a little gap in the bushing large enough to fit a screwdriver in and wiggle the arm over to align it. then just hold the lower control arm still while u quickly put the bolt thru. it'll take a little wiggling of the lower control arm to fit it all the way thru to catch the nut on the other side but its not hard. just make sure u dont cross thread it.
ok i got the tie bar in with the help of another friend. it took over an hour with lots of wiggling and going up and down with the jack. It wasn't fun... For those who want to install a lower tie bar it helps TO REMOVE THE WHEEL FIRST. Also helps if you have another person to help you align the bushing while the other does the wiggling.
snosurfa7
Oct 4, 2007 03:26 PM
FlipHKD720
Aug 12, 2006 03:28 PM
D16z6
May 22, 2006 09:24 AM
Fibercation.com
Nov 28, 2005 11:32 AM
