help with spring rates
Im going to get Ground controls for my hatch and use them with my KYB AGX's
im looking to tuck tire on hxs
no real racing ambitions (drag strip occasionally, maybe try autox once or twice?)
its 91 civic dx for those who dont know
so my ? is should OTS spring rates b fine for me or should i get custom rates ( if so what suggestions?)
The standard spring rates worked fine for me, and my EJ1 was a little heavier than an EF is, so I don't see why you'd need firmer springs. Be aware that you're going to be replacing struts fairly often as the AGX's start leaking relatively fast with that low of a drop. It's one of those "pay to play" type deals.
well its the agx's off the rex so ill be using those
if i decided to switch to koni yellows later could i buy whatever special thing i need to make the yellows work with my GC's?
i think itll only b like an inch lower than i have on my rex (not even then as low as u were) do u reallythink they will still start leaking that fast?
Lost
Mar 17, 2008 08:04 PM
