It's really time to lower my car, Need some help
Old Jan 29, 2007 | 06:55 PM
Nail I3unny's Avatar
Default RE: It's really time to lower my car, Need some help
ORIGINAL: jhsplaya08
as far as springs go, i would get s-tech over the h's. i have a set of h&r sport springs that im selling for 150 shipped.
buy these
ORIGINAL: drbyers
id personally never consider tein springs. ive read reviews where they actually induce more understeer on my model car (but I have an integra)
believe it or not 9/10 sets of aftermarket springs induce understeer before oversteer (ok that statistic ismade up...but a lot of them induce understeer). this is because this is how the stock suspension is set up. car companies have the basic idea that it is easier for your average street driver to control understeer than oversteer (because if you hit the brakes while inducing oversteer you will lose control completely, while it wont nessecarily have this effect on understeer). they do this by having stiffer springs in the front, softer in the back. this means that the rear has more lean to it and is cusioned more in the corners. since the front cant compress as much as the rear, it is up to the tiresto hold the road, and if the front suspension isnt compressed as much as the rear that means there is more lateral force as opposed to the downward force in the rear. this means the front will skid out before the rear and you will have understeer. now...true to the original design idea...most aftermarket companies design their springs with stiffer spring rates in the front and softer spring rates in the back. soooo...easiest way to fix this: put the springs intended for the front in the back, and the ones for the back in the front. the only thing that specifies one from the other is spring rate, so you will be set.
damn that was a lot longer than i expected....sorry
buy H&R Sports and put them on Tokico Illuminas. you will not be sorry.
Old Jan 29, 2007 | 07:33 PM
mxs's Avatar
mxs
ORIGINAL: Nail I3unny
ORIGINAL: drbyers
believe it or not 9/10 sets of aftermarket springs induce understeer before oversteer...most aftermarket companies design their springs with stiffer spring rates in the front and softer spring rates in the back.
this is very true. Tein is not to blame, if you look at the spring rates for most off-the-shelf setups, the back is softer.
I don't think you can just switch fronts and rears (unless you're using ground control sleeves or something similar) because the spring lengths are different
Old Jan 29, 2007 | 08:21 PM
D16Punk's Avatar
What do you guys think of these 2? Which one would be better?
http://performance.thepartsbin.com/b...p;brandid=2641
I dunno why it says 4dr at the top, but every site I went to kept saying 4dr even when I just searched for 2dr.
The drop seems to be a good height, just want some of your guys opinions.
Old Jan 29, 2007 | 09:41 PM
jhsplaya08's Avatar
i totally agree with nail I3unny here. i have read alot into the illumnas and was planning on running them with the h&r's that i bought. now i have changed my mind and have 0 intentions of using the h&r's. they will fit a 92-00 2dr.civic if anybody is interested .
Old Jan 29, 2007 | 09:56 PM
i was under the impression that you could switch front and backs?
maybe thats just with coilovers.
Old Jan 29, 2007 | 09:59 PM
mxs's Avatar
mxs
if jhsplaya has his springs just sitting there, he can open the box and tell us if they are all the same length
Old Jan 30, 2007 | 05:31 PM
D16Punk's Avatar
Is this still my thread? lol, bastards...
What do you guys think of the set I posted in my last reply?
Old Jan 30, 2007 | 05:45 PM
mxs's Avatar
mxs
ORIGINAL: D16Punk
adjustable shocks are better than non-adjustable
but both sets are good
Forty has the first one, I think
Old Jan 31, 2007 | 06:27 AM
mybrokenblinker's Avatar
Yes forty does have those, i talked with him about them and he really liked them...im going to get some soon check out this link i found for a great deal
http://www.directtuning.com/store/sh...it-civic-96-00
Old Jan 31, 2007 | 09:45 AM
D16Punk's Avatar
ORIGINAL: mybrokenblinker
I think I might go with those aswell. They're also cheaper than the one I posted. Thanks mbb.
krystencivic99
Jan 21, 2008 12:09 PM
romic00
Oct 19, 2007 07:04 PM
ginsunh
May 2, 2007 08:31 PM
Partizan
Jan 25, 2007 09:13 PM
apexi_89
Jul 28, 2006 11:43 PM
