Quick question on lowering..
Old May 20, 2007 | 10:09 PM
jpat_5's Avatar
Default Quick question on lowering..
Since im wanting to lower my car, would it be easier to get coilovers instead of buying shocks and springs seperate?
Old May 20, 2007 | 10:15 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: Quick question on lowering..
coilovers are not the same as full-coliovers.
coilovers are just the spring and adjusting perch part. There slip over shocks, which you should upgrade right away.
full-coilovers are full strut replacements, which in the spring, shock, and and adjusting perch all-in-one.
If you are looking for easy, full-coilovers will relieve you of one or two steps, that's all. The hardest part of the job is not breaking bolts and the easiest part is the strut assembly.
Old May 20, 2007 | 11:03 PM
jpat_5's Avatar
so i should look for a full coil over kit.
Old May 21, 2007 | 09:39 AM
secondhandloser's Avatar
It won't make that much of a difference... the biggest thing is that full coils are often ride-height adjustable, whereas I don't know of any spring/shocks combos that offer that. That said, you can usually save yourself a little bit of cash by buying everything seperate, as long as you figure out what kinda drop you want.
Old May 21, 2007 | 12:50 PM
cderalow's Avatar
unless you plan on tracking the car, or want to change the ride height constantly, don't bother with coil overs
you're better off with a matched spring/shock setup from a reputable manufacturer
Old May 21, 2007 | 02:23 PM
civicexracer's Avatar
"full-coilovers" are prolly impractical, mainly because of price,if all u want is a nice stance and decent handling. u can get a good set of shocks and sleeves if u want adjustable height, i'd recommend tokico blues and skunk2 sleeves, good ride and not to pricey. if u dont really care for adjustable height, then get a nice shock/spring.
Old May 21, 2007 | 07:29 PM
bks85's Avatar
Member
+ 1 Full-Coilovers are more expensive than a spring/shock setup.
rs634158
Apr 10, 2008 08:05 PM
hondahb
Mar 1, 2006 10:56 AM
domestic disturbance
Jan 15, 2006 12:35 PM
THE_CRIPPLER
Dec 6, 2005 08:26 AM
RedCityRunner
Apr 13, 2005 08:56 PM
