Running on stilts
Old Apr 5, 2007 | 07:10 AM
roundkat's Avatar
Default RE: Running on stilts
my .02
I put a "plus zero" on my RX330 and actually noticed that there
really wasn't a whole lot of difference...
That being said.. If you just go wider... let's say 20 mm (which is a bit over 3/4 of an inch)
that also increases the sidewall (which I agree with a previous poster) which gives you
more cushion..
A co-worker has a 2005 LX M/T and has 17" rims on it (a daily driver) and he thinks it rides
to rough.. I *think* he has 225/40/17 which (to me) are like bicycle tires... :-)
Old Apr 5, 2007 | 09:11 PM
Kommando's Avatar
Make sure you are running the proper pressure in your tires. The sidewall number is the MAX pressure you should never exceed. This is NOT usually the pressure you should be running your tires at. Chalk across the treads and roll the cara few meters to check for even wear. Wear on the edges means not enough air. Wear on the middle means too much air.
Run adjustable shocks/struts or put back in the soft stock springs andinstead improve your handling by way of stiff anti-swaybars and sturdy strut-tower braces. If the ride is still harsh, pick a rim/tire setup that has more sidewall to it.
Old Apr 5, 2007 | 09:24 PM
hum.... never heard the chalk idea.......
Old Apr 6, 2007 | 07:58 AM
ORIGINAL: Inev
Alright, I currently have 17" rims and it feels like I'm running on stilts, I feel every single move in the road. What can I change to the suspension to make it feel like a better ride?
Ditch the 17's
kjreinha
Feb 4, 2005 01:58 PM
nwhite82
Jan 13, 2005 10:39 PM
INJENalltheway
Jan 5, 2005 07:24 PM
outlawzz23
Jun 30, 2004 10:49 PM
AdamC
Jun 2, 2004 04:10 PM
