running lean!??!
Old Jan 12, 2005 | 11:36 PM
nwhite82's Avatar
Default running lean!??!
i have a 88 civic 4 door w/B16A, skunk 2 cams, skunk2 intake manifold, aem cold air, msd ign., msd wires/dist., nos 75 shot wet nitrous, 2 bottle nos setup, act clutch, act flywheel, dc sports header, 2 1/4 custom exh.,jg adj. timing gears, ngk plugs, aem fuel rail, aem fpr, bbk fuel pump, what should my fuel pressure be around. i have it at 43psi and the car is still running lean. can i push it past 43psi?
Old Jan 13, 2005 | 06:03 PM
sacicons's Avatar
Default RE: running lean!??!
yeah, a little past that should be fine. if you go too much you can blow out the seals in the injectors. you probably need a piggyback though.
Old Jan 13, 2005 | 10:34 PM
nwhite82's Avatar
whats a piggyback? ecu upgrade???
Old Jan 13, 2005 | 10:39 PM
sacicons's Avatar
kinda. its a computer that tricks the stock ecu into running the air fuel ratios you want.
ssewall
Dec 31, 2011 06:29 PM
civic_turbo
May 2, 2008 02:18 PM
Shingpumps
23
Jun 23, 2007 12:49 PM
VTECivic95
12
Nov 9, 2006 02:09 PM
Street Sniper
Aug 18, 2005 12:26 AM
