S-Tech HELP!!!!!
Old Jul 29, 2007 | 06:29 AM
Strong Island's Avatar
Default S-Tech HELP!!!!!
which springs go in the front of an EG and the rear!!!! do you just match them up with the ones you take out?? cause ones bigger than the other(teins) and the front has like a 220lb spring rate while the back is supposed to have like 140lb so im guuess the smaller spring goes in the back?
***********NEVERMIND IM AN IDIOT!!!!! i just read the numbers on the side of the springs*****
Old Jul 29, 2007 | 09:44 AM
Default RE: S-Tech HELP!!!!!
lol glad you got that sorted out... now get those springs on and snap some pics! (Oh, and you might as well just order new LCA bolt before you even start the install)
Old Jul 29, 2007 | 04:15 PM
i already had new blox LCA's which let me tell you came in handy!!!! changing the struts and springs are a ****n PAIN! every god dam bolt was rusted solid...thank god for the new lca's cause the the bolt that connects the lca to the strut in the rear left didnt come out so i just said **** it and left it in, after soaking it in WD-40, then heating it with a torch. i had a bolt laying around that was just about an exact match, so i used that. My complete list of things i did was changed: out the old struts and springs with KYB AGX's and Tein S-Techs, changed the rear LCA's(lower control arms) with a set of BLOX. changed my oil.......to synthetic blend and got new brake pads which i was going to install but i was burnt out so thats another day. As for the pics ill have them up tomorrow or so cause its f'n raining here in NY.
lilfed857
May 16, 2014 04:39 AM
XCM828
51
Jan 23, 2010 04:57 PM
truwon
Apr 5, 2007 10:06 PM
LEVIII
Oct 14, 2005 12:56 AM
LEVIII
Sep 2, 2005 01:53 PM
