Serious sway bar help!! pics
Old Aug 26, 2007 | 01:22 PM
Strong Island's Avatar
Default RE: Serious sway bar help!! pics
yeah i always put axle stands under her...but i just jacked it up real quick to check if i could figure out how to mount it. u can see the stands to the right of the pic
this **** is rediculous.....the bar 19mm thickor round....should i just buy a whole kit? they are very expensive though like $250 https://www.hondacivicforum.com/m_473783/tm.htm
he is selling the gsr sway bar with mounts? that **** fit my EG??
Old Aug 27, 2007 | 02:48 PM
BlackDX's Avatar
From what I"m seeing the eg and dc use the same rear brace which means his mounts shouls work for your eg....... I tried looking up the OE part numbers for the factory brackets but couldn't find any....
Old Aug 27, 2007 | 03:09 PM
civicexracer's Avatar
u'll need to buy aftermarket LCA's if u dont already have them or get them from an integra. im not 100% sure but u may also need to drill a couple holes into the subframe to mount the d-brackets, its not a big deal tho.
Old Aug 27, 2007 | 03:27 PM
yeah i got blox lcas on her now
Old Aug 27, 2007 | 03:34 PM
BlackDX's Avatar
Actually the sway bar you have doesn't use the factory mounts. As I said/showed above it uses the shock bolt to mount the bracket that the connection rod connects to. If an OE sway bar n links were used then yes you'd need the OE mount holes on the lca.
xsquizet
Jul 28, 2009 12:50 PM
Nerosync
Oct 25, 2007 09:06 AM
Big T
May 29, 2007 01:17 PM
FlipHKD720
Aug 12, 2006 03:28 PM
D16z6
May 22, 2006 09:24 AM
