some kind of noise when turning the wheel
Old May 1, 2005 | 05:11 PM
bleedhondos's Avatar
Default some kind of noise when turning the wheel
when i turn my engine on and turn my steering wheel toward my right i hear some kinda squeaking noise not sure if its a squeaking noise. I went under to check my axle and dont see anything wrong with it. It seem like its something to do with my suspension. Could it be my supsension?, anyone have imput or have this happend to them before?
Old May 1, 2005 | 07:30 PM
polo708's Avatar
Default RE: some kind of noise when turning the wheel
Are you sure its not your tires just making noise (since they arent spinning)? That, or your CV joint is about to take a dump on you, or you might need some power steering fluid?
Old May 1, 2005 | 08:11 PM
how can you tell if you cv joint is going die on me, would there be a tear of the boot? im going to double check my steering fluid but i dont think that is the problem. I know it isnt my tire thats making the noise. My friend said that could be a bent on my strut....
Old May 1, 2005 | 08:27 PM
i read somewhere it could be the bushing......where is that located?
Old May 1, 2005 | 08:48 PM
StifflersMom's Avatar
Cat Fuсker
depends which one
Old May 1, 2005 | 09:29 PM
bushing from the front right side.
Old May 2, 2005 | 04:21 AM
polo708's Avatar
problem with CV joints is that they are constantly flexing, after a while they get torn or ripped and water seeps inside. Its a pivoting joint with oil but the water will create more friction and begin to rust the metal joint. If you can see your CV joint then check it for cracks or tears... if you see some then thats probably your problem.
Old May 2, 2005 | 12:00 PM
LEVIII's Avatar
ORIGINAL: bleedhondos
There are tons of different buching in there
sanderson
Mar 5, 2008 08:53 AM
pimpciv98
Jul 31, 2007 11:06 AM
hliau
May 30, 2007 01:18 PM
alwaysneednewrubber
Apr 24, 2007 05:09 PM
petezamory
Jun 6, 2006 08:44 AM
