struts and springs???
Old Dec 29, 2006 | 10:16 PM
bgd99s10's Avatar
Default struts and springs???
i have a 00 civic coupe, im droping it 2" and was curious if i get kyb struts (non adjustable) will it lower it anymore? i cant go any lower than 2" and drive it comfortably, anyways thanks
Old Dec 29, 2006 | 10:28 PM
mxs's Avatar
mxs
Default RE: struts and springs???
shocks don't lower your car, the springs determine ride height. what springs are you looking at? there are a lot of options around that drop range
Old Dec 29, 2006 | 10:53 PM
bgd99s10's Avatar
i know they dont but ive heard some of them make the car sit a little lower, was thinking bout the H&R limited springs, there 2.0 upfront and like 1.8 outback i believe, should put the car right where i want it but any lower its going to scrape the fenders
Old Dec 30, 2006 | 10:14 AM
drbyers's Avatar
DOOOOO EEEET.
but make sure you get aftermarket struts.
a two inch drop will probably wear out your OEM struts pretty fast.
KYB GR-2 non-adjustables are OEM replacement struts for hondas and acuras. they have almost identical build dimensions.
btw, a two inch drop in the front will require camber kits.
1.8 inch drop in the rear will probably require either a camber kit or you doing the free "washer" trick to correct camber.
Old Dec 30, 2006 | 10:26 AM
bgd99s10's Avatar
thanks man, thats what i needed to hear...
SoCaL.rider
37
Nov 26, 2007 10:28 AM
Marknhl
Jun 18, 2006 03:17 AM
Forty04
Mar 29, 2006 01:49 PM
Fibercation.com
Mar 4, 2006 09:20 AM
bain0005
Aug 1, 2005 04:51 PM
