uh oh!! HELP
Old Sep 23, 2007 | 06:13 PM
jhsplaya08's Avatar
Default uh oh!! HELP
yea....so i stripped out my lca bolt. the one behind the rotor. i finally got a set of those sockets that are suppose to dig into the bolt to get it out. it dug into it alright. i had a pipe on the ratchet to get levrage and i broke the bolt in HALF!! now there is like 3/4 of the bolt still in there. what do i do? how can i get this bolt out now? and i cant mess up the threads on the backside either.....as you can see it broke right in half.
[IMG]local://upfiles/3700/80F31CDC48F24AA68197FC4EDB813762.jpg[/IMG]
[IMG]local://upfiles/3700/319AED7841C74E33AF91B517C5538103.jpg[/IMG]
Old Sep 23, 2007 | 06:34 PM
civicexracer's Avatar
Default RE: uh oh!! HELP
is there a little nut tack weldedon the other side of the hub? i cant remember...if so, u can break the tack welds by just putting enough tq on it trying to loosen it like a regular nut. when the welds break, tighten the nut. it'll pull the bolt out of there when u tighten it. once u run out of threads on the bolt, use a punch and hammer the hell outa the bolt to push the rest out. if u get it out, just buy a new nut for the new bolt and tq it down like normal.
thats the first thing i'd try. next would be trying to drill it out which would take alot longer and be harder..
Old Sep 23, 2007 | 07:02 PM
StifflersMom's Avatar
Cat Fuсker
Welcome to the world of rear LCA's Do what AJ suggested first...it'll work
Old Sep 24, 2007 | 04:34 AM
jhsplaya08's Avatar
i dont understand....break the nut that is on the back? how am i gonna get it back on there?
Old Sep 24, 2007 | 04:38 AM
amg6975's Avatar
You don't, just use a regular nut (and prob. washer) to put it all back together. Actually, you can probably just reuse that nut but it just won't be attached anymore. The nut being attached as no effect on holding the bolt in once it's tight, it's just there so it's easier to get the bolt in and out.
Old Sep 24, 2007 | 05:50 AM
Cat Fuсker
if you want you could tack-weld it back in there once it's tightened...it makes no difference
stevenc
Jun 25, 2008 09:57 AM
redridinhood
Oct 9, 2006 07:27 PM
superballa22
Sep 18, 2006 05:06 PM
coolguy1234
May 7, 2006 08:31 PM
Jas10hon
Jul 4, 2005 10:35 PM
