Vibration?
Old May 30, 2007 | 07:25 AM
mlobitz's Avatar
Member
Default RE: Vibration?
ORIGINAL: rit14623
Possible causes of vibration when braking
1. warped rotors
2. wheels are out of alignment
3. tires are unbalanced
When was the last time you had brake work done? Machining down rotors is not a bad thing to do, also called "turning down rotors", unless they are machined beyond a minimum rotor width.
No one said it is bad to do, just that it will likely occur again with a thinner rotor, and probably sooner.
Replace your rotors and pads and bed as directed, you'll be fine.
It doesn't matter if your car is 10 years old or 10 days old, you can still have warped rotors.......
mahmi
18
Nov 4, 2006 08:30 PM
safian
Nov 7, 2005 01:37 PM
jbum
15
Oct 4, 2005 06:39 PM
US3R!!!11one
Jun 7, 2005 02:33 PM
kjreinha
Dec 21, 2004 03:24 PM
