When should i install coilovers?
Old Sep 15, 2010 | 12:19 PM
mnight's Avatar
Default When should i install coilovers?
I'm planning on buying Skunk2 Pro S coilovers for my 00 civic. First of all, does it matter if its colder out when i install them? Also, i checked out the DIY section, but i thought i'd get more opinions on installing them myself. Is it that hard? Or is it as simple as unbolting a couple bolts and re-bolting the new ones on? Any advice is appreciated.
Old Sep 15, 2010 | 12:34 PM
When you should install them = ASAP.
It is really not as hard as you may think. A couple bolts and whatnot for both the rears and fronts. The hardest part is removing the OEM suspension/bolts.
However, make sure you research the dreaded seized rear LCA bolt and how to overcome it prior to just going in and wrenching around. The fronts are the easiest.
Old Sep 15, 2010 | 09:00 PM
theblackpearl's Avatar
when the stock handling and body roll really bugs you
BrillianceLin
Aug 31, 2011 10:08 PM
arcmt33
Nov 20, 2009 02:34 PM
acadw001
Feb 18, 2008 10:54 PM
Steven T
Dec 7, 2007 10:57 PM
s0ulj3r
Nov 28, 2007 09:20 PM
