1993 Civic Coupe DX with a H23???
Old May 20, 2012 | 10:58 AM
Mainegd21's Avatar
Default 1993 Civic Coupe DX with a H23???
My axle on passenger side slips out a little bit probably around 1/4 an inch...but car still drives...it throws all my gear oil out and vibrates a little due to axles being out...i got the car as is (i didnt do swap) it has h23a1 (out 1994 prelude non vtec) and trans...how do i fix this?
thanks for help
Old May 21, 2012 | 10:28 AM
droopy128's Avatar
wonder if it have a mid-shaft install?? mine did the same when I was running a ZC LSD, I got rid of that tranny next day.
Old May 21, 2012 | 01:12 PM
Figure out what axles you have. I run 90-93 Integra (non-abs) axles with an Accord half shaft. I have to spread the c-clip open with pliers a little to help it snap into place (passenger side of course).
The vibrations are the axles binding due to the angle of the motor and the axles being too "long". This depends on the engine mount set-up you have. What mounts are you running?
Mainegd21
Jun 1, 2012 05:38 PM
Mainegd21
Apr 25, 2012 03:48 PM
sneekapeek
Apr 5, 2008 08:52 AM
spooncivic
Sep 16, 2007 09:57 AM
mezaff
Feb 19, 2006 10:54 PM
