5 Speed Not Shifting inot any gear????
Old Jul 17, 2005 | 10:25 PM
lraicovi's Avatar
Default 5 Speed Not Shifting inot any gear????
Just replaced motor and freshly rebuilt 5 speed transmission, 97 civic ex--- vtec d16y8.....Problem is trans. won't shift into any gear, trans had synchros for 3rd and 4th replaced as well as shift fork and bearings......clutch was replaced and is operating normal, car appears to be stuck in gear, no neutral......any help or ideas would be appreciated...
thanx
Old Jul 17, 2005 | 11:29 PM
sacicons's Avatar
Default RE: 5 Speed Not Shifting inot any gear????
take it back to whoever rebuilt the trans. if the clutch is working properly, the trans is screwed up.
Old Jul 25, 2005 | 08:59 AM
lraicovi's Avatar
UPDATE>>>>
I brought the trans back to the trans shop, was told that I was responsible, and that I had to have power shifted into second gear, as all the teeth on the gears, both mainshaft and countershaft were ground off........ended up getting a junkyard trans......would never do business with this shop again>>>>>>>Staria Transmissions in selden,ny.........worst experience of my life as far as mechanic goes......
Old Jul 25, 2005 | 08:56 PM
sacicons's Avatar
report them to the Better Business Bureau, ASAP. thats BS, you never even moved the car with the trans in it, did you?
Old Jul 26, 2005 | 12:35 AM
Mad7s's Avatar
Small claims court is your friend.
Old Jul 26, 2005 | 12:54 AM
sacicons's Avatar
no joke. thats total BS.
Old Jul 27, 2005 | 02:29 PM
lraicovi's Avatar
I think I will, thanks for the advice......
dsmoore
Mar 13, 2018 08:25 AM
russell
Mar 6, 2008 01:06 PM
tampaandy
Apr 23, 2007 07:49 PM
ajfd90
Jan 7, 2007 12:35 AM
xe1002
May 24, 2005 05:49 PM
