Changed my MT fluid today
Old Jun 23, 2007 | 10:27 PM
conceptualpolymer's Avatar
Default Changed my MT fluid today
Car: 97 Civic CX
I had to rotate the tires, anyway, so I decided to change the tranny fluid. It does help to remove the right (passenger side) tire if you don't need to rotate them, since it makes getting to the plugs a bit easier.
MT fluid: Because I heard and saw too many conflicting bits of advice as to what to use, I played it safe and bought some Honda MT fluid at the dealership for $3.75/quart. The tranny needs 2 quarts, only.
Getting the plugs out: Unless you are as strong as the incredible Hulk, you will probably need a pipe or large box-end wrench to go over the handle of your breaker bar or ratchet wrench.The drain plug is a 3/8-inch recessed square, so no socket is required. ALWAYS make sure you can loosen the fill plug before draining the fluid.
Plug washers: Each plug uses an aluminum washer; the fill plug's is much larger than the drain plug's. The parts guy gave me a fill plug washer, indicating that the drain plug washer rarely needs to be replaced. However, I found that the drain plug washer had a raised lip, both on the outside periphery and on the inside (near the I.D.). I therefore sanded the raised lips off using a beltsander and wet&dry paper on a flat surface. Do NOT simply reassemble an aluminum washer that is not flat and parallel. You could end up with a leaky plug.
Pumping in the fluid: It REALLY helps to get ahold of a fluid pump. I have one that I bought from Amsoil and it comes with a few different length extension tubes that allow it to pump fluid from the bottom of almost any length container. It does help to have a helper hold the tube in the fill hole while you pump in the MT fluid, but is not absolutely necessary. I guess you can always gravity-feed the stuff in from the top of the engine bay, but the pump really comes in handy if you HAD to do it, yourself.
Torque: I have a 1/2-inch drive torque wrench and couldn't quite get it to fit over the hex filler plug head, so I tightened that one by feel. The service manual calls for 36 lbs-ft (I believe) and I was able to use the torque wrench on the drain plug, using a 1/2-to-3/8 drive adapter.
By the way, torque for the wheels is 80 lbs-ft and having a big torque wrench helps alot.
Dave
Old Jul 18, 2007 | 06:55 PM
Shingpumps's Avatar
Default RE: Changed my MT fluid today
I wanted to do the same to my 95 turbo'd dx. A macanic told me to stick with what i had, the high mileage tranny might not like the new fluid. Did you have any trouble afterwards?
pippo
Jun 16, 2014 12:08 PM
colby_666
18
Dec 18, 2009 05:43 PM
enigma34
May 13, 2009 06:41 PM
Lost
Mar 25, 2008 11:18 AM
dave_57204
Nov 15, 2007 09:24 PM
