CLUTCH
Old Aug 21, 2005 | 04:17 AM
smokingemcee's Avatar
Default CLUTCH
my clutch grabs too late, how do you adjust it to make it grab earlier?
Old Aug 22, 2005 | 07:58 AM
maachan513's Avatar
Default RE: CLUTCH
If your car is with the clutch cable like mine, there should be adjuster at the transmission. Turn the adjuster to where you like to engage.
Old Aug 22, 2005 | 11:23 AM
Default RE: CLUTCH
I have a hydro tranny. . . .
Old Aug 22, 2005 | 12:25 PM
maachan513's Avatar
Default RE: CLUTCH
When I had other car (not Honda) equiped with hydraulic clutch, I made adjustment at master sylinder, where pedal and the rod meet. Either extend or retract the rod to where you need.
Old Aug 22, 2005 | 10:08 PM
sacicons's Avatar
Default RE: CLUTCH
how many miles on that clutch? im thinking its nearing the end of its useful life, and you need to save a little money
Old Aug 23, 2005 | 08:13 AM
maachan513's Avatar
Default RE: CLUTCH
What's "sylinder?"
It must be "cylinder", , ,
ORIGINAL: maachan513
Old Aug 24, 2005 | 09:56 PM
Default RE: CLUTCH
i don't think it's dead yet, it still grabs. . . thanks for the help
Old Aug 24, 2005 | 10:52 PM
maachan513's Avatar
Default RE: CLUTCH
If you have a problem with the timing of clutch engagement, one thing I can think of you maybe doing. There should be a travel limit bolt for the pedal on the fire wall. If you extend this bolt you will be able to shorten the travel of the pedal from the bottom to where engagement happens. This will make your clutch timing earlier than you have now. If this is what you are after, you shouldn't have to mess with other adjustment.
Other thing I can think is, , , you will get used to what you have on the car now in no time. In other words, you will learn how to handle the car in sooner time than you know.
VXHatchHero
Jun 13, 2010 09:42 AM
NIKE H34D
Jan 5, 2009 01:04 PM
addiction2bass
Apr 13, 2008 05:19 PM
jtvision
Jan 11, 2007 07:58 AM
HARI.
Oct 8, 2006 09:46 PM
