loose sts
Old May 9, 2006 | 12:34 PM
slottieskim's Avatar
Default loose sts
00 ex. installed a sts and it feels real loose and there is soooo much freeplay while in gear(i can move it side to side as if it were in neutral). im not sure if that is normal. and going from 4th to 5th and R the very bottom of the stick bumps the exhuast it doesnt bother me i just dont kno if its soppoesd to. but all in all the actually function of the sts is working perfectly.
Old May 10, 2006 | 12:08 AM
Default RE: loose sts
so no one has any input??
Old May 17, 2006 | 01:59 PM
Clean98EX's Avatar
the only thing that i would do is go back and retighten all the bolts on the shifter assembley. The exhaust problem is common but im no sure what i would do for that
Old May 18, 2006 | 09:36 AM
Did you replace bushings when you did the install?
lauzon
Jul 6, 2007 04:03 PM
xramseyx
May 1, 2006 10:22 AM
mill$civic
Sep 27, 2005 01:06 PM
all2common
Jul 19, 2005 07:40 PM
altezza
Apr 17, 2005 10:33 AM
