Oil
Is it possible to change what type of oil that you run in your car? Say from regular oil to Synthetic? I have heard you can and i have heard you cant so i want to know from more experienced guys. thanks.
Synchromax is recommended for manual transmissions that specify an automatic transmission fluid or motor oil.
Synchromax is formulated with Royal Purple's synthetic, proprietary Synerlec additive technology, which offers improved shift quality over a wide temperature range and reduced gear noise.
Synchromax is fully compatible with all types of friction materials and offers excellent corrosion and oxidation protection without affecting the soft metals commonly found in manual transmission synchronizers.
this should be fine, make sure you read as much about it before buying it to ensure you can use this kind of tranny oil.
If you are looking for motor oil then i can promise royal purple is one of the best oils....
just keep in mind one fact... synthetic lubricates to well!! which is only a problem if you engine is not broken in.... never use it in new engines or if you have done any mods, like cams, it will not allow the parts to wear in.
Seafoamgreencivic
34
Aug 12, 2008 09:30 AM
oilltd
Jun 10, 2008 04:06 PM
oilltd
South West
Jun 10, 2008 03:07 PM
Vadagar
May 26, 2006 12:51 PM
