Problem - Wont go into gear - help
Old Jan 3, 2006 | 09:32 PM
FastFwd's Avatar
Default Problem - Wont go into gear - help
hey guys, i got a b16a2 swap on my 92 hatch about 6 months ago, for the first month it was all working fine but but after that the gears got hard to change. and i couldnt slam gears i would have to slowley put them in and not rev it hard. until 2 days ago it was like that then i went to start it and my gears wouldnt go in. i turned off the car put it in gear then started it - the car was moving but i got it started. it felt like i was starting it with it in gear with the clutch out. does anyone have any idea's what it could be.
maybe loose flywheel - thats what i thought
Old Jan 3, 2006 | 11:40 PM
finalimpact's Avatar
Default RE: Problem - Wont go into gear - help
maybe a leaky slave of clutch master? sounds like your clutch isnt fully engaging when pushing in the pedal. id check the clutch fluid level and go from there.
91Honda
Aug 27, 2012 01:43 PM
subestol
Jul 7, 2010 08:18 PM
ak82la
May 29, 2010 05:12 PM
Russ.
20
Sep 23, 2009 10:24 AM
99civicwhat
Jun 6, 2005 08:22 PM
