Problems with my tranny
Old Apr 19, 2008 | 12:54 AM
Gonzo's Avatar
Member
Default Problems with my tranny
So I have an automatic Civic. It's in great condition and has never given me any problems. Only about 56,000 miles on it. But..
Today I was cruising around and noticed my car was acting weird. When it shifted it would kind of give a quick shudder. Like a bang. And it would kind of jump forward a bit. Hard to explain I know. But it's getting worse. And now whenever I switch into drive, or have my car shift it gives a pretty noticable bump.
Here's the real problem.
I have a date tommorow. I really wouldn't want to cancel, and even worse, I don't want to make her drive. So is there any things that you could think of that could be an easy fix and could do before tommorow around 3? Or if not, do you think it would be okay to drive my car about 15 minutes each way somewhere?
Old Apr 19, 2008 | 06:25 AM
Default RE: Problems with my tranny
Your tranny fluid may be low. Check fluid level when engine is warm and idling. Add a Honda recommended transmission fluid. You'll need a special funnel from an auto parts store to do this.
Old Apr 19, 2008 | 12:22 PM
Gonzo's Avatar
Member
Checked the fluid.. At the right amount, and clean.
I'm thinking the tourque converter?
Old Apr 19, 2008 | 12:55 PM
macbeth18288's Avatar
ORIGINAL: Gonzo
You don't cycle through your gears like it's a manual tranny, right?
By that I mean you thrown it into neutral at a stop light, then put it into "D1" or whatever and work your way up.
Old Apr 19, 2008 | 05:59 PM
Gonzo's Avatar
Member
ORIGINAL: macbeth18288
ORIGINAL: Gonzo
Naw, I don't do that. I know that's super hard on a transmission.
Old Apr 19, 2008 | 11:31 PM
Does it happen all the time?
On a cold start?
Does it warmed up?
Any CELs coming up?
Might just want to take it to the shop.
Tranny is not just something you can ignore, haha
You pretty much need it.
If you run with it while it has problems then you may be doing more damage.
Old Apr 20, 2008 | 12:21 PM
Gonzo's Avatar
Member
Yeah, It's being taken into the shop. I haven't driven it in the past couple days for fear of doing more damage. (I'm rolling in the parents Corrolla) xD
Old Apr 20, 2008 | 12:42 PM
Well, be sure to keep us updated on the diagnosis.
I'm interested to hear what is wrong.
Good luck
Old Apr 20, 2008 | 12:43 PM
Gonzo's Avatar
Member
Yeah, I'll keep you guys posted.
I'm interested in what's wrong, too. Haha.
Old Apr 25, 2008 | 07:59 AM
andywy2007's Avatar
well,i think maybe is the outo clutch-plate is out.better go to forman n check it out.
[align=left] [/align]
sway2003
Apr 22, 2008 12:15 PM
Civic Dx 349
Nov 7, 2007 06:35 PM
davster
Sep 28, 2007 10:23 AM
pregohatch
Jul 9, 2006 09:21 AM
darknightmr2
Mar 14, 2006 06:44 PM
