Shift grinding between second and third
Old Apr 16, 2009 | 10:17 AM
Tranqz's Avatar
Default Shift grinding between second and third
I drive a 93 SI Coupe (canadian) ,standard and when my car is cold, the shift from second to third is smooth, but once it warms up, it starts to grind a little bit unless I double clutch. I've been told something is wrong with the syncro, and that a transmission fluid change might do the trick for fixing it, any ideas what else it could be? I haven't been able to change the transmission fluid, as I'm away from home.
Old Apr 16, 2009 | 10:41 AM
Start by replacing the MTF with Honda MTF.
Old Apr 16, 2009 | 10:42 AM
Tranqz's Avatar
Alright, thanks, I plan on doing that as soon as I get home.
Old Apr 18, 2009 | 12:21 AM
It's the syncro, and it's a common problem for a grind to develop between second and third on the D-series transmissions.
Change the MTF as instructed. Use genuine Honda MTF.
Old Apr 20, 2009 | 07:17 PM
Tranqz's Avatar
Well, just got finished changing the transmission fluid, and it didn't completely eliminate the grind, but it definitely helped, and it doesn't grind if I don't drive like an idiot and shift real fast.
bakrueger
Aug 28, 2011 12:03 PM
AndreaAlexia08
Jan 4, 2011 08:13 AM
nathanswid
Jul 29, 2009 09:26 PM
colby_666
May 20, 2008 01:26 PM
HaZe89
Jun 25, 2006 01:05 PM
