Slave Cyinder...AGAIN!
Old Apr 23, 2009 | 06:22 PM
plethoric33's Avatar
Exclamation Slave Cyinder...AGAIN!
Ok. I had my slave cylinder replaced about a month and a half ago when it went out. Just now I had the car towed to the shop again because it went out again. So my question is...what would cause a slave cylinder to go out twice in 2 months? It was replaced with a new one by a pro last time, so its not that it was done by someone shady. My car has a b18 swapped in, so if there is anything from a swap that could cause this, inform me.
Old Apr 24, 2009 | 05:29 AM
The shop I took it too said its going to continue to go bad every couple months because of the way the slave cylinder has to be mounted. Its a hydro tranny and he said it should have a cable. But I have seen other people with this same setup so what are they doing to make it work?
Old Apr 28, 2009 | 08:59 AM
rburnett's Avatar
It might me mounted differently on a cable tranny vs. hydro, as in more severe angle between the cylinder and the clutch release fork. That's the only thing I can think of, maybe someone else will chime in. Is the slave for the cable and hydro the same part #?
Old Apr 28, 2009 | 06:50 PM
Yeah, I figured it out. It now has a home made bracket to make it a straighter shot. Its my solution instead of buying the $200 ones Ive seen.
saturn78
Apr 19, 2007 01:36 AM
sway2003
Dec 27, 2006 07:33 PM
drbyers
Nov 15, 2006 05:14 PM
01CivicEX
Apr 20, 2006 01:38 PM
JDMcivic
Sep 19, 2005 08:57 AM
