Speedometer.....130 in First gear?
Old Nov 30, 2006 | 12:07 AM
Hailchristian's Avatar
Default Speedometer.....130 in First gear?
1988 Civic Hatchback 4speed manual
Today my Speedometer went crazy. It worked fine last night but this morning (temp was bout 40 degrees Fahrenheit) it went crazy. What happens is after my speed gets past about 20 mph the speedometer goes crazy and starts whining and then goes all the way past 130 and continues to whine and stay past 130 until i stop. I drove it home at about 6:00pm and the temp was probably about 60 and it did the same thing. When i got home i pulled out the cable and the boot and it is missing the spring clip that holds it in. I dont know if that is the problem or if i need a new cable or a new speedometer unit or what...
Any suggestions?
Old Nov 30, 2006 | 06:13 AM
ic892003's Avatar
Default RE: Speedometer.....130 in First gear?
seems like u might need a new speedsensor
Old Nov 30, 2006 | 09:09 AM
love_my_si's Avatar
130 in first gear? to me it just sounds like VTAK!!! was kicking in lol. sorry, i couldnt resist, i have no idea man, good luck.
Old Dec 16, 2006 | 10:56 PM
SilverSedan's Avatar
sounds like either the speed sensor or the speedo cable is possessed.
I recommend an exorcism! (j/k
Old Dec 17, 2006 | 11:32 PM
94SOHCTURBO's Avatar
haha mine does that in the snow.... haha
Old Dec 26, 2006 | 07:25 PM
nautik's Avatar
How fast do you go in second?
Old Dec 26, 2006 | 08:04 PM
ya id replace the cable.... it might have been cold and some water got into it locken it up alittle and just jacked the cable up....
id replace that first and if that doesnt fix the problem its either in the cluster or tranny...
but most likely its jsut the cable gone bad...
Y_dolan
Sep 10, 2013 11:58 AM
honda_dud
Jul 10, 2009 06:48 PM
chasemclemore
May 18, 2009 04:21 PM
MasterJT
May 18, 2008 05:37 PM
98HatchVtecRatio
Oct 30, 2007 01:27 PM
