synchro replacement
Old Jan 5, 2007 | 10:26 PM
bp4131017's Avatar
Default synchro replacement
so when the synchro's are bad, you need the synchro hub and sleeve to fix it...
and you know which synchro's are bad just by which gears are hard to go into...
so i have the service manual that shows you how to do everything, would it be worth it to replace the 2nd, 3rd, and 4th synchro's and put everything back together with the gears that have been ground as a result of the synchros?
or take a chance on a used transmission...
and on that note, i have a 1997 dx, any d series transmission would work correct? even from an eg?
Old Jan 18, 2007 | 11:40 AM
VTECivic95's Avatar
Default RE: synchro replacement
id take my chances with a used tranny, chances are your gonna need to replace gears too, i know i had to, but the person before me ran the **** out of the old clutch and gears/synchros/sliders/etc.
acidlittle
Jan 14, 2013 10:02 AM
bolts
Jan 18, 2007 04:17 PM
weirddan455
Jun 22, 2006 10:10 PM
amg6975
Sep 14, 2005 08:23 PM
volcom_mike06
May 5, 2005 02:03 PM
