Tranny Issue Help
im having this problem, i shift to 1st gear no prob, 2nd gear and it jumps back to N, 3rd gear fine
basically i cant stay on 2nd cause it jumps back, anyone had this before or know what i should do? is it the whole tranny?
please help [sm=dontgetit.gif]
i had the same sort of problem with my stock tranny. what happened was the bearings had worn to the point that when i would shift, it would move all the gears inside enough so that the actual shift mechanism couldnt quite lock into gear. so the bad news is, youll probably need a new tranny. the good news is, thats not nearly as bad as it sounds. you can find a used ex tranny for under 100 bucks. just start looking around. oh, and you might want to consider a new clutch while youre in there.
Thats what every one tells me, that im going to need a new tranny and its going to cost me at least 600+ for everything including labor. Where would i start looking for a used ex tranny? do tell. and i was planning to change the clutch as well
mudhenFUF
Jan 16, 2023 08:43 PM
MBrent
Sep 11, 2009 01:35 PM
