new gas great acceleration old gas not so great acceleration
Old 11-01-2008, 07:39 AM
burgernuds's Avatar
Default new gas great acceleration old gas not so great acceleration
hi whenever i pump new gas into my car the first few days and usually right after pumping the acceleration is great. Then towards the end of the week, usually when the tank is half full acceleration sucks. I used lucas fuel injector cleaner 2 months ago and i didnt really feel the difference. my car is an 01 at 58,600 miles
Old 11-04-2008, 12:36 PM
brutekiller787's Avatar
not to be a d!ck but so? what are you asking?
Old 11-04-2008, 03:33 PM
Have you tested gas purchased at different stations? Is the effect the same regardless of where the gas is purchased?
Old 11-04-2008, 05:38 PM
burgernuds's Avatar
im asking if there is anything wrong with engine or gas line to cause that.
im using shell and have only used shell at the same gas station locally. Im afraid to mix gas or go to any other shell because the one that i use has such a spacious area and the ramps are small.
Old 11-04-2008, 11:17 PM
If you think it might be the quality of the gas, try BP. No need to get anything more than regular 87 octane.
I have found BP gasoline to give me the best results by means of gas mileage. I would assume that gas that gives you the best gas mileage is probably the best quality gasoline.
My first guesses though would be clogged fuel filter, weak fuel pump, or clogged fuel pump filter. Possibly water in the gas tank too. Try pouring 1/3 a bottle of seafoam into your gas tank with the next fill up, this will help rid the gas tank of possible water.
Old 11-06-2008, 06:07 AM
burgernuds's Avatar
i'll have the shop check out all that youve mentioned. But i'll wait until its really noticeable. thanks
ohheynix
02-29-2012 05:05 AM
asechrist
01-06-2009 08:14 PM
sboarder97km
03-19-2008 02:32 PM
Garon
11-01-2007 07:03 AM
cannonierd
05-04-2007 12:57 PM
Quick Reply: new gas great acceleration old gas not so great acceleration
