97 civic exhaust manifold cracked
Old 01-17-2012, 09:42 AM
amitsekhon's Avatar
Default 97 civic exhaust manifold cracked
Hello guys, I have 97 civic lx(Canadian model) with 185000 kms.I just found that my exhaust manifold is cracked and i am getting bad gas mileage.I have heard that its a common problem with civics.I need your suggestion with 2 things:
1. If i install aftermarket steel header and install vtec catalytic converter (from vtec engine under the body style)and extend the secondry o2 sensor wiring, will it run OK in terms of engine noise and gas mileage?
2. Is there any way i can install vtec exhaust manifold (including cat)from civic si (from junk yard) and do that way?
My main concern is to remove the cracking problem, gas mileage and less engine noise.If you guys have any other better suggestion?? Thanks in advance.....
Last edited by amitsekhon; 01-17-2012 at 10:28 AM. Reason: description of vtec cat
Old 01-17-2012, 10:11 AM
Ramyswar's Avatar
What's a vtec cat?
Old 01-17-2012, 10:28 AM
amitsekhon's Avatar
Originally Posted by Ramyswar
What's a vtec cat?
catalytic converter from vtec engine like from acura or si. thx
Old 01-17-2012, 10:33 AM
Ramyswar's Avatar
Ohhh, and vtec exhaust is same thing but its the exhaust? I think now I understand.
Old 01-17-2012, 11:41 AM
Read/look through all stickies prior to posting. It seems as if you have an understanding as to where you would like to go with the swap.
Header, Intake, & Exhaust - HondaCivicForum.com
The first sticky in that section tells you what you need to know.
Old 01-17-2012, 12:10 PM
amitsekhon's Avatar
Thanks for the reply bro!!.Yes actually i did go through the sticky already.But my question is that will it affect the performance bcoz primary o2 sensor is going to be away from the engine than the oem design of lx . and will it make the engine noisy? As in Canada we don't have civic ex with vtec engine,so which vtec model's catalytic converter i can use. And can i swap it without welding anything using whole system from any Canadian model like acura 1.7 el? thanks again...
Old 01-17-2012, 12:55 PM
Canadian SI = USDM EX.
You shouldn't hear any changes in noise unless you run an aftermarket cat converter. If anything, it will help performance slightly since the "vtec" cat set-up allows the motor to breathe easier.
Old 01-25-2012, 12:16 PM
amitsekhon's Avatar
thanks for your reply! i just found a used manifold from 200 civic and i will post results after that.thx again.
Big_Al98
08-05-2014 11:22 AM
kadir
01-15-2010 05:33 PM
bxmas13
04-09-2007 07:18 PM
mybrokenblinker
09-10-2006 08:34 AM
2spooky
03-22-2006 09:25 AM
Quick Reply: 97 civic exhaust manifold cracked
