timing belt change
Old 05-02-2005, 03:43 PM
ahhsimon's Avatar
Default timing belt change
hi im new here, and im not really in to cars and all but i believe that timing belt change should be 60k-70? and probably 90k for civic cx since it has about 106hp and its a sohc, so it doesnt cause my stress on the timing belt? ?? im not really sure i got confused on reading some of the forum stuff, but im on 79k and do u guys think my timing belt would last to 90k and should be changed asap? ?
correct me if im wrong ,
Old 05-02-2005, 04:07 PM
Default RE: timing belt change
It's best to go ahead and replaced it. It's much cheaper than taking the risk of it breaking. 60K is a good interval although many of the models reccomend 90K.
Old 05-02-2005, 10:18 PM
sacicons's Avatar
yeah, at 79k youre justified in changing it, though it MAY last well past 100k, its not worth it. you can change it yourself if you have a somewhat decent mechanical knowledge base, and a decent set of tools. it will cost you around a hundred bucks off of Ebay to do it and the tensioner pulley, along with the waterpump, which should almost always be done with the timing belt.
Old 05-02-2005, 10:23 PM
LEVIII's Avatar
oh yeah, timing belts are fun fun fun
Old 05-02-2005, 10:45 PM
sacicons's Avatar
at least it isnt a stupid H22 TB.[:@]
Old 05-02-2005, 10:48 PM
LEVIII's Avatar
ORIGINAL: sacicons
Oil pressure owns you
Old 05-03-2005, 03:01 AM
ahhsimon's Avatar
i remmeber hearing that to tell if u need a timing belt change, can be known by hearing how many sounds it take to start the car .. but anyways i set my mind in changing my timing belt at 82-85k danx for the advice yall
Esquirrel
28
03-07-2012 02:51 PM
2DHX
04-28-2006 05:58 AM
thakid
01-30-2006 08:29 PM
powderdude
13
09-20-2005 12:18 PM
91DXHatch
12
12-07-2004 08:01 PM
Quick Reply: timing belt change
