Hooking Up Second Amp...
Old May 11, 2007 | 08:47 PM
Bostonhoodhop's Avatar
Default Hooking Up Second Amp...
Ok i Got My New Amp... That I Am Hooking Up Tho The Interior Speakers... Now Im Gonna Hook The Rca's to the output of the 1st amp?? and i was wondering instead of wiring everything through the car again... can i hook the new wires up to the other amps wires??? figured it would be easyer hookin them up together??? plz let me know... thanx
Old May 11, 2007 | 09:45 PM
Marty's Avatar
Default RE: Hooking Up Second Amp...
man I will give you a good in depth answer when I wake up, I just way to damn tired to right now but if you could tell me what 2 amps you are running
Old May 12, 2007 | 04:08 AM
thi3v3z's Avatar
If you have one amp for ur sub, and 1 amp for ur components you need 2 sep rcas. As for power wires u can use a dblock, but u will need a 4 channel rca to connect yo your front and rear outputs on ur hu.
Old May 12, 2007 | 05:57 AM
jeff948594's Avatar
if his headunit doesnt have 3 sets of pre-outs for rca's but his 4ch has an output he can just run like a 3ft rca from his 4ch to to his sub amp to save time and money he just wont have independent sub control
Old May 12, 2007 | 11:20 AM
well are you talking about the RCA cables or the power/ground wires?
if the RCAs those should be fine using the output on one of the amps going to the other.. or just some Y adaptors will also work....
BUT the power/ground wire is a whole different story!
the wire needs to be large enough for the voltage its pullen thru... same as ground wire...
but since i dont know what size wires you already have ran and whats the RMS ratting on the two amplifiers combined... i cannt tell ya...
that_guy5
Mar 1, 2009 09:17 PM
Rhino40
Jan 18, 2009 11:56 AM
jhsplaya08
Oct 18, 2007 04:33 PM
Phalcon
Mar 27, 2007 10:28 PM
Bostonhoodhop
Mar 10, 2007 06:26 PM
