Going to start turbo project need help with internals
Old Jan 18, 2009 | 12:17 AM
Cyphen's Avatar
Default Going to start turbo project need help with internals
okay so i was looking around for h-beam rods, and i was look around at eagle but http://www.jegs.com/p/Eagle/744628/10002/-1 i wanted to run a 9:1 comp in my motor b16a my goals where around 230 hp and being able to be a RELIABLE KEY WORD RELIABLE dayly driver, and im going to go with fully automatic turbo timer and a af-wideband going to do it right/ so can somone help me i have full valve train and i want to change pistons i heard ITR and CTR where nice brands but i need help selecting piston with h beam rods was going to go wtih http://www.treadstoneperformance.com...23&phot_key=82 for a turbo kit with a greddy rs bov, and i was goin to use the stock pipes they offer and waste gate
Old Jan 18, 2009 | 01:26 AM
230whp in a b16a doesn't need a build
anyway, turbo kit looks good.
if you're building, definitely get eagle rods, get arp rod bolts, idk about pistons, and also get arp head studs
P.S. ITR and CTR aren't brands, ITR means integra type R (B18C5) and CTR means civic type R (B16B)
Old Jan 18, 2009 | 02:06 AM
Cyphen's Avatar
so you think i should be okay with the stock internals to boost on 6lbs for a daily driver?
anyone know a good site for prices on fuel components/turbo timers/boost control?
Old Jan 18, 2009 | 11:58 AM
Well, 6lbs doesn't really mean anything at all. Different size turbos need different amounts of boost to make the same power. It depends what turbo you are using.
Instead, make your goals based on WHP. I don't know off the top of my head the stock internals limit of a B16, but I know it's higher than 230
get a name brand turbo timer and harness from ebay
for injectors search honda-tech's marketplace, they're always selling them
walbro fuel pump kit on ebay
boost controllers can be found on honda-tech too
Old Jan 18, 2009 | 12:23 PM
Cyphen's Avatar
will do thanks this turbo project will be done in about a month ima post vids when i get my car on the dyno. if i have any more questions il post here.
mlawhun0114
EG Swaps
Nov 16, 2011 07:20 AM
soafed
Apr 7, 2007 03:27 AM
dfdon
Jul 29, 2006 11:31 PM
blkwidow
Jul 27, 2006 03:03 PM
ballplaya4eva07
14
Mar 7, 2005 09:06 AM
