Does my car have 1 or 2 Camshaft and Crankshaft Seals
Old Jan 31, 2009 | 07:49 AM
WILMER007's Avatar
Default Does my car have 1 or 2 Camshaft and Crankshaft Seals
The owner of a local goodyear who will be performing the timing belt job for my car (sounds like he's a timing belt expert) told me the rear camshaft seal needs to be replaced but not the front one. He says theres 2 camshaft seals , he also mentioned the front crankshaft seal. Now my question is, do both the cam and crank have 1 or 2 seals. I thought and from looking at diagrams my car had 1 camshaft seal and 1 crankshaft seal not a front and rear like he's saying...
Is he wrong or right? If is he's right than i'm confused as to which camshaft seal it is. Is it:
RUBBER, R. BACK SEAL
RUBBER, L. BACK SEAL
OIL SEAL (29X45X8)
Old Jan 31, 2009 | 08:23 AM
One camshaft oil seal (front)
Two crankshaft oil seals (front and rear)
Phone the part department of your local Honda dealership or enter your VIN at Majestic Honda.
Old Jan 31, 2009 | 09:24 AM
WILMER007's Avatar
I'm going crazy RONJ
I called my local honda dealer the guy from parts told me it's a plug but he couldn't give me the part number.
I need to findout what are the exact parts because i'm been trying to order the damn parts for the timing belt but these damn seals keep preventing me from ordering a i'm not sure what the correct ones are.
Crankshaft Seal - 91212-PLM-A01 OIL SEAL (38X50X7) (YAMADA)
Camshaft Seal - 91213-P2F-A01 OIL SEAL (29X45X8)
Now if i have 2 cranshaft seals then why do i only find one?
Can you help me RONJ i need to order these parts ASAP.
Old Jan 31, 2009 | 09:53 AM
To ensure that you are ordering the correct oil seals and plug, enter your VIN at Majestic Honda, and then view the rear crankshaft seal (80X100X10?) in the Cylinder Block-Oil Pan section, the front crankshaft seal (38X50X7?) in the Oil Pump-Oil Strainer section, the front camshaft seal (29X45X8?) in the Camshaft-Timing Belt section, and the cylinder head plug in the Cylinder Head section.
Aaron A Archer
Nov 29, 2011 08:37 PM
Mecca8383
Jan 30, 2011 01:07 AM
amace013
Apr 28, 2010 08:40 PM
crazzyyj
Oct 17, 2006 11:24 PM
