1993 honda civic dx reverse lights not working
Old Apr 24, 2009 | 11:39 AM
churritos567's Avatar
Exclamation 1993 honda civic dx reverse lights not working
when i put the shifter into revers. i ben told that my lights dont work so i check the bulbs and there fine but i replaced them anyways and theys till dont work. please help!
Old Apr 24, 2009 | 11:49 AM
I assume you have a manual transmission?
1) Check whether fuse 15 under the dash is blown.
2) With the transmission in reverse, do you measure battery voltage at the bulb socket?
3) If the answer to (2) is no, then check the switch attached to Yel and Grn/Blk wires on the transmission:
Old Apr 24, 2009 | 11:50 AM
Check the fuses next of course, then the switch. On a manual the switch is on the transmission; it is very simple with two wires. Unplug the switch and jumper the wires on the car side and see if the lights come on (remember the key must be on). If it's automatic the switch is at the shift lever and it's more complicated because the switch does other things but the concept is the same, jumper the wires and see if the lights come on. If you have power from the switch but not back at the bulbs and it's a hatchback, it's likely the wires broke where they flex every time the hatch is opened.
Old Jun 24, 2009 | 09:27 PM
the bulbs i replacved it with were bad thanks!
Old Jun 25, 2009 | 06:54 AM
alexfergwan's Avatar
hey,
Check to see if your reverse bulbs are working. If thats not the case, its your reverse sensor.
burnindesirez02
Feb 15, 2010 06:32 PM
churritos567
Nov 6, 2009 09:30 PM
pinto
Mar 15, 2007 05:58 AM
gin0o0o
Jan 23, 2007 10:10 PM
chrisroug
Oct 2, 2006 11:36 AM
