brake drum leak
Old Jul 25, 2009 | 09:31 AM
bigmikew1's Avatar
Default brake drum leak
i was gonna bleed my brakes a while ago and i step on the brakes and see brake fluid coming from the left drum. i was gonna jus replace the parts, but im guessing i should be replacing the whole drum?
Old Jul 25, 2009 | 10:37 AM
no you dont have to replace the whole drum just take tire off and drum cover and there is a brake wheel cylinder that went bad easy /cheap fix there is 2 10mm bolts on the back side that hold it on. make sure to remove the brake line first. make sure ebrake isnt on also may have to tap drum with a hammer.
Old Jul 25, 2009 | 09:32 PM
bigmikew1's Avatar
yea i saw it. but u think i should change both sides?
Old Jul 25, 2009 | 10:03 PM
I would, but thats just me. They're both the same age and if one is leaking... the other may soon follow.
Old Jul 28, 2009 | 01:15 PM
bigmikew1's Avatar
o noooo idk what to do. i cant take the the nut off for the brake line that connects to the wheel cylinder, on BOTH sides. when i try to turn it just rubs, so its making it round.
Old Jul 29, 2009 | 09:34 AM
norbster86's Avatar
Buy a set of these line wrenches: http://autorepair.about.com/od/tools..._line-wren.htm
They should break it free. Unless it's already been rounded badly.
Good luck!
Old Jul 29, 2009 | 01:25 PM
vise grips works great use them. and also make sure you are turning it the right way.
phearly
13
Mar 22, 2020 07:52 AM
FanTasTicRidE
Oct 9, 2011 05:16 PM
jc6711
14
Mar 5, 2007 06:20 PM
HaZe89
Aug 17, 2006 12:08 PM
mxs
Detailing/Paint DIYs
Dec 29, 2005 01:17 AM
