Broken Rear LCA bolt
Old Jul 4, 2010 | 11:11 AM
SiPex's Avatar
Default Broken Rear LCA bolt
Sure enough, when I was putting on my new springs, the head of the bolt where the LCA connects to the strut came right off. The other bolts came out fine though.
I picked up a new LCA and new struts. For now, I'm using a bolt that matched the size of the original one that I found from pepboys. Will this work fine? Or should I get a factory bolt to put in there?
Old Jul 4, 2010 | 11:39 AM
StifflersMom's Avatar
Cat Fuсker
You want the OEM bolt. It's way stronger than any garbage pepboys has. Though you will pay about $10-12 for one.
Old Jul 4, 2010 | 01:31 PM
SiPex's Avatar
Alright, thanks. Should I just call the dealer and have them order one? Or is there somewhere I can pick it up online?
Thanks
Old Jul 4, 2010 | 07:36 PM
civicexracer's Avatar
Dealer would probably be the fastest, ordering online will only save you a couple bucks probably..
Old Jul 4, 2010 | 08:12 PM
You don't want to order that online. They'll rape you with shipping. They use a pretty flat-rate system and you'll end up paying $10 shipping just for a couple bolts.
Old Jul 5, 2010 | 02:45 AM
SPLAT's Avatar
This happened to me once, after the bolt broke i replaced with another one off the shelf,
50 miles latter it broke.
Get a OEM one.
Old Jul 5, 2010 | 05:43 PM
kanarrjl's Avatar
I just got a grade 8 bolt off the shelf and have been fine but you would want to go with a grade 8 for sure.
Old Jul 13, 2010 | 05:35 AM
GDizzle2's Avatar
order from www.hondapartsunlimited.com i get all my bolts, OEM equipment from there all the time. i broke mine off last sat & ordered new ones. they have eveything and they ship within a week
Old Jul 23, 2010 | 06:04 AM
tbaybucs's Avatar
same happen to me when i bought my civic [ except the idiots welded the strut where the bolt's broke] i went to a junk yard and got the bolts for 50 cents a piece
Spoolin.Em
Sep 21, 2011 05:04 PM
Blue_Rocket_WRX_STi
Sep 17, 2009 03:17 PM
chase07
Nov 9, 2007 04:52 PM
snosurfa7
13
May 18, 2007 02:08 PM
snosurfa7
13
Apr 27, 2007 01:44 PM
