Can I Use Dipstick Hole to Fill ATF?
Old Oct 15, 2008 | 08:07 AM
sbg20307's Avatar
Default Can I Use Dipstick Hole to Fill ATF?
i would like to change the ATF in my 99 ex.
is there any downside to using the dipstick hole for the ATF to use as a filler hole for the auto trans fluid?
Old Oct 15, 2008 | 08:10 AM
In conjunction with a funnel, this is precisely the recommended method. Use either Honda ATF or a Honda-recommended ATF.
Old Oct 15, 2008 | 08:20 AM
sbg20307's Avatar
Thanks. I wasn't sure that the filler hole and the dipstick hole were the same. I assumed there was some square bolt like the drain hole for the filler hole (that I didn't want to find and crack open).
Old Oct 15, 2008 | 04:19 PM
yea use the dipstick hole
the filler bolt method is used for manual transmissions
Old Nov 5, 2008 | 12:36 AM
Civic|UnLimiteD's Avatar
so when changing tranny fluid u put it in through the dipstick hole?
Old Nov 5, 2008 | 10:19 AM
only for an automatic
and it's the dipstick on the transmission
i think there is actually a fill bolt, but it's so much easier to use the dipstck
Ska-T
Feb 27, 2012 03:06 PM
DeanHensler
Jan 9, 2012 08:06 AM
briceman124
Aug 13, 2011 03:31 AM
MaximusFunk
Apr 9, 2010 03:28 PM
ymchen
Aug 28, 2008 01:35 PM
