Need help on more power
Old Dec 22, 2004 | 11:35 PM
  #21
rico892002's Avatar
Member
Default RE: Need help on more power
what do you mean
Old Dec 22, 2004 | 11:41 PM
  #22
Vovka86's Avatar
Is your car 5sp or auto and was sunfire 5sp?
Old Dec 22, 2004 | 11:59 PM
  #23
rico892002's Avatar
Member
my car is a 5 speed and the sunfire was a 5 speed
Old Dec 23, 2004 | 08:39 AM
  #24
fast93civic's Avatar
Ok, here's a list of some of the things you need to obtain about 150-160 HP. Be ready to dish out about $1500 or so, take your time make the money, and you'll get the power. Use Ebay to your advantage. By the way is your car a 5 speed? Most of these mods are a bolt on so you should be able to do it your self, or have your dad give you a hand. Also, get your self a Haynes manual.
AEM V2 Cold Air Intake or K&N, or Injen intake will be good
Holley 62 or 68mm Throttle Body
Skunk2 Intake Manifold
Performance Spark Plug Wires
AEM or OBX Fuel Rail-
Venom 400 Performance Control Module, disigned to put more gas in to your engine=torque
Slightly Bigger Fuel Injectors-
DC Sports Header, or any other good header
Cat Back Exhaust, 2.25 or 2.5 inch piping
Cam Gear
Increase Compression Ratio 10:1
Andrey
Old Dec 24, 2004 | 08:41 PM
  #25
rico892002's Avatar
Member
thanks fast93 civic i have a ? i was going to by cam gears i really don't know what they do if i get them what i do i just bolt them on and there goes the HP or what i have to tune something if i have to tune something i'm not getting the i really don't want to mess up the timeing
Old Dec 25, 2004 | 05:05 PM
  #26
Ok, well cam gear/gears wont really do that much for you. I mean you can get one, replace the stock one with say like a AEM, advance the timing, that will increase your compression ratio to about 10:1 and you'll have to use premium gas, and you'll gain maybe like 2 HP or so. Usually cam gears are handy when you have some mods done to your engine, like a turbo, bigger cam etc. If you're just starting out, and on a budget, what I would stick with for now is getting a cold air intake, a bigger throttle body, a header, and a cat back. This will be a good point for you to start from. You'll gain say about 20 HP or so, and you'll learn how to work around your car. Then as you save more money, and learn even more about your engine and tuning, you can get in to heavier stuff like intake manifolds, and head swaps. For now just do the basics.
Andrey
Old Dec 25, 2004 | 09:28 PM
  #27
rico892002's Avatar
Member
how do you tune the timing to 10:1 and can you answer my forum on premium gas please
Old Dec 26, 2004 | 08:56 AM
  #28
You advance your ignition by tuning the cam gear I believe 18 degrees. That increases your compression. But that really wont give you any good gains other than like 2 horse power. I would'nt worry about it. Get a cold air intake, a bigger TB, a header, and a cat back, then you'll notice some thing different about your car.
Andrey
Old Dec 26, 2004 | 07:18 PM
  #29
technically, it doesnt "raise the compression" it starts the combustion event earlier, causing a rise in cylinder pressure. the compression is a fixed ratio between the volume of the cylinder at TDC and again at BDC. but its kind of the same end result. and yeah, its 18* BTDC.
coke
Mar 21, 2006 09:23 AM
91crx_87
Sep 18, 2005 09:36 PM
carlover
Jun 20, 2005 10:40 PM
wingswestcivic
May 19, 2005 02:52 PM
nwhite82
Feb 9, 2005 11:01 AM
