Airbox?
Old Dec 15, 2006 | 06:48 AM
  #31
Kerok's Avatar
Default RE: Airbox?
Hmm...I honestly would do that if I didn't have to make the alt line ten feet longer.[sm=laughat.gif]
Old Dec 15, 2006 | 01:01 PM
  #32
mill$civic's Avatar
Default RE: Airbox?
ORIGINAL: Kerok
How to move your battery to the back
Old Dec 15, 2006 | 04:09 PM
  #33
Kerok's Avatar
Default RE: Airbox?
Not too shabby, thanks for the link. Only thing I think he should have done different is move the ground to a different location considering most people roll with their spare tire in the trunk. I'm sure it's lighter if you take it out and takes up a fair bit of room but puts you in a bad spot if you blow a tire. From my knowledge the ground should be as short as possible from the battery so instead of running it to the spare tire spot because the bolt is available, drilling a spot right beside the battery to bolt to. I also think that line loss might become a problem to the alt although using 1/0 cable is a good idea...the shorter the better.
Old Dec 15, 2006 | 11:14 PM
  #34
Impreza WRX's Avatar
Default RE: Airbox?
ORIGINAL: cpl rampage
that box is actually a resonater to create a smoother airflow to the engine do to the normal pulsing suctuion, it also makes it a bit quieter
A LITTLE quieter? My car is [insert adjective] LOUD without the resonator! And I got a 93 EG8, with the D15! Hamsters can make lots of noise without that giant empty box of a resonator.
Also, when you remove it, make sure to plug up that hole with something, or water WILL go up your filter!
Old Dec 16, 2006 | 06:23 AM
  #35
WhiteRabbit1021's Avatar
Default RE: Airbox?
IT'S DEADWEIGHT! RIP IT OUT.
Old Dec 16, 2006 | 11:10 PM
  #36
SilverSedan's Avatar
Default RE: Airbox?
Kerok,
I live in Manitoba, I took out the stock intake system, and am running an SRI setup. I've had no problems so far, but I think my next project is a battery relocation. To bad my stock battery crapped out last week and i had to buy a new one
mill$civic
Sep 6, 2006 08:09 PM
Toppers
Nov 24, 2005 08:33 AM
j_fukin_t
Sep 3, 2005 10:33 AM
Auto98EX
Aug 8, 2005 11:16 PM
jeffro
Jul 26, 2005 12:03 PM
