is this ok tranny fluid?
Old Mar 30, 2007 | 02:50 PM
Kedawei's Avatar
Default RE: is this ok tranny fluid?
ORIGINAL: ic892003
u dont needa delaership connection to get gm syncromesh u can get it online for cheap,but y do mechanics say i dont have transmission fluid guys??
I'm talkin free. Online it's what, 7, 9 dollars a quart? 10W-30 is ~2.50.
Old Mar 30, 2007 | 09:33 PM
ic892003's Avatar
so for the transaxle, wat is recommended motor oil or transmission fluid?
Old Mar 30, 2007 | 10:29 PM
Kedawei's Avatar
Your trans oil is all you have to replace. Honda manual reccommends Honda MTF. Some use regular old 10W-30.
Old Mar 31, 2007 | 03:40 PM
ic892003's Avatar
thanks kedawei, one more thing what exatly is the transaxle, and whats the diff between it and a transmission, so should i go to the dearlership and buy mtf?
Old Mar 31, 2007 | 05:47 PM
ef4life's Avatar
don't waste your coin on mtf from the dealer. i have before and it made no difference than when i used 10w30. but its your car do what you want.
and the honda owners manual says 10w30 oil for the trans too.
Old Mar 31, 2007 | 07:39 PM
ic892003's Avatar
im confused, so i can use eitehr one motor oil or honda mtf?
Old Apr 1, 2007 | 01:12 PM
ef4life's Avatar
yes either 10w30 motor oil. its actually is in the onwers manual. or honda genuine manual trans fluid, or gm synchromesh.
none of them are proven to be better than the other. this debate has been going on for a long *** time. and chances are if you took your car to a honda dealer they would put 10w30 in you car because its cheaper.
i have run both and they is no difference in the smoothness of shifting or the longevity of your transmission.
Old Apr 1, 2007 | 10:27 PM
ic892003's Avatar
ill probably jus get get the honda mtf to give me piece of mind, so xcan someone explan to me the difference between the transmission and transaxle?
Old Apr 3, 2007 | 11:44 AM
the_turtle's Avatar
ORIGINAL: Kedawei
yea, the dealer i went to, ( im pretty familiar around there)told me not to waste my money on MTF, he said they dont even use it unless a customer request's it be used. so, i trust my honda guy, and i filled up with 2 qts. of castrol synthetic, and damn is it smooth, way better than when it had 70k on the stock MTF.... but do what you want. its a really easy "fix" oh, and an easier way to fill it is removing the vechicle speed sensor on the top....
Old Mar 15, 2008 | 09:41 PM
ebaben3's Avatar
ORIGINAL: ic892003
http://en.wikipedia.org/wiki/Transaxle
http://en.wikipedia.org/wiki/Transmi...28mechanics%29
pippo
Jun 16, 2014 12:08 PM
enigma34
May 13, 2009 06:41 PM
Jeremy102579
May 21, 2005 08:05 PM
AnakinKenobe
Apr 24, 2005 06:23 PM
induction1
Oct 19, 2004 11:51 PM
