Dare I Paint It???
yesh it is, considering everything it can do.
i don't think i'll ever put a cd in it, simply because it can play either my iPod or USB drive.
i read a review online that another buyer also hooked up his USB portable hard drive!
that's crazy.
that's crazy.
DAmn i hate flip faces... but with the ipod intagration i may not need cd's.. and the External drive idea is pure genious. just stick the drive in your glove box and run the wire behind the dash... then have a second cable when you need to transfer more music.. genious, pure genious... I LOVE IT!!!!
ORIGINAL: kamlooper
What I would do is scuff it up lightly with a scotchbrite pad (multipurpose) then thouroughly wash in soap & water, rinse and let it completly dry. For painting Id spray with Krylon fusion. Id spray 3 light coats then let paint cure for 3 days. Then Id give it a clearcoat, the first coat being an extremly light coat followed by 3 light coats. Then let cure for 2-3 days before install.
EDIT: hell i didnt know you have already done it, i didnt read the whole thread, but hey it looks good
you don't have to do anything with Krylon Fusion. it does recommend you wipe down the plastic part with paint thinner slightly, but it's not a requirement.
I sprayed my trim plate the first time without doing anything (except the thinner wipe down) and krylon worked as advertised.
but it was TOO glossy. so I sanded the trim plate down with 600 grit paper to give it a more matt, rough finish and sprayed it with satin fusion paint.
after a few coats, I then sprayed it to resemble a pebbled texture to match the other interior bits. I didn't use any gloss or finish it down with super grit paper or anything because I wanted a more weathered look.
Krylon Fusion is teh shizNat when it comes to painting plastic. Just don't get it on your hands. it's sticky as hell.
Steven T
Dec 5, 2007 08:24 AM
Auto98EX
Nov 22, 2005 03:56 AM
