OEM Stereo Adapter
I have a 97 DX hatch, someone had an aftermarket HU intalled befoe me and they cut off the OEM 16 promg plug.
Can I use one from a 98?
I found a plug from a 98 at the junk yard and I hooked it up I do have three wires that don't go anywhere I think two are for an amp.
I wired the stock radio to the 98 16 prong plug but it still doesn't work.
Are you wanting to instal another aftermarket deck?
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H
Do Not Use
I
Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N
Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
Typical Honda/Acura
brianrwebb
Aug 2, 2006 10:20 PM
TylerN
Mar 9, 2006 01:26 PM
