check engine light
Old Feb 26, 2005 | 12:34 AM
bubbaray's Avatar
Default check engine light
I have a 1998 Honda Civic EX a/t. I am trying to get it smogged. The car runs fine no problems, the check engine light never comes on while driving. The car failed because the check light come on during the obd2 check. They were saying the car needed to be driven to reset the ecu. So I did and it had the same problem. Can someone out there help me out.
Thank you for your time
Old Feb 28, 2005 | 09:29 PM
PhBsCivic34's Avatar
Default RE: check engine light
Hey Well I have had that problem so what I did was i either stuck my key in the gauge cluster bext to the mileage reset, or you can down where your ecu is where they hook up a ecu check you can take a paper clip and put in into the 2 plugs and it should take it off thats what Mine did.
Hope it helps
Old Mar 12, 2005 | 12:16 PM
Mossy's Avatar
disconnect your battery for a few minutes to reset it, not drive it around
miguel11691
Nov 15, 2015 08:11 PM
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
Benny Sim
Jul 19, 2005 07:43 PM
