EK Swaps 1996-2000 Civics
98' Ex getting a B16A2
Old Feb 28, 2006 | 12:07 PM
sandrider123's Avatar
Default 98' Ex getting a B16A2
Okay so I have decided that I will for sure be swapping a B16A2, into my 98' EX coupe. So I need someone to give me a complete parts list that I will need to purchase, and what I will have to do. Oh and what generation of motor do I need. I want something that I can put in and have minimal wiring problems. Thanks in advance
Old Feb 28, 2006 | 12:38 PM
Default RE: 98' Ex getting a B16A2
another question is will i have to run premium fuel or will 87 octane be okay to put into it?
Old Feb 28, 2006 | 01:59 PM
smokingemcee's Avatar
No, no, no use the highest octane at the pump. Use premium! B16's are high compression!!!!!!
You are going to need a b-series engine mount kit and shift linkage for 96-00. Your also going to probably need a wire for knock and a wire secondary 02 sensor pinned into your harness. I'm not sure if anyone makes a harness. . . . I did a b16a1 swap into a 90 si and I had to wire those with a hasport harness that also included v-tec and v-tec oil pressure, but since your car is an ex you sould already have those.
For sure your also going to need a conversion harness that takes you from 0bd2 - 0bd1 for that b16a2 ecu to plug in. That's good though because tuning capabilities with obd1 are endless. You can find those on the internet everywhere.
Your also going to need some b-series axles. If I were you I'd go to a local shop and ask for some (94-00) integra axles cause a lot of the time they come with a lifetime warranty.
You are also going to need special washers for the shift linkage, and prolly some other random nuts and bolts.
goodluck
Old Feb 28, 2006 | 02:01 PM
oh yeah, you also probably need a throttle cable from a 94-00 integra.
Old Mar 1, 2006 | 11:47 AM
Do all the VTEC B-series have to have premium?
Old Mar 1, 2006 | 10:48 PM
Well I called the stealership today and I talked to a mechanic and he told me that I dont have to run premium with the B16A2. So can someone tell me what all i will need?
Old Mar 1, 2006 | 11:30 PM
sacicons's Avatar
give me that dealerships number and the techs name so i can call and bitch him out. thats BS. honda dohc vtecs are all over 10:1 compression (except the oddball b17, i think its just under 10) you have to run premium. it even says so on an Si fuel door. what a tool. (the tech, not you)
Old Mar 2, 2006 | 09:26 AM
Its Bill rogers honda the number is (541)-928-0122. The tech guys name was well im not sure, just bitch out the first guy that answers the phone. So If I have to run premium can you tell me what stuff can I do to my D16Y8 to get a decent amount of power? And Boosting is not an option, I dont want to boost not to mention my dad would flip a bitch.
Old Mar 2, 2006 | 10:01 AM
Kedawei's Avatar
Intake, headers, exhaust, high flow cat. Maybe a set of pulleys, but I've heard those have problems. A lightweight flywheel and LSD would be good upgrades as well. I think that's about all you could do. It won't be as fast as a b16, but you'll still be able to use 86-87 octane, as well as gain gas milage.
Captain_Sl0w
Oct 4, 2008 03:05 AM
civic_driver_389
EK Swaps
13
Oct 24, 2007 05:55 AM
97b16swapcoup
Jan 16, 2005 05:13 PM
Blackhatch124
EK Swaps
Nov 5, 2004 09:56 AM
Blackhatch124
Sep 26, 2004 10:44 AM
