ANOTHER BIG QUESTION
Old May 11, 2006 | 07:42 PM
F23AccordLX's Avatar
Default ANOTHER BIG QUESTION
I jusr recently bought a 94' D16Z6 and i am putting some new OEM parts on it like T-belt, water pump, idler pulleys, tensioners, i/m gasket, e/m gasket. And all of this has to go into a 97' Civic EX. I Need To Know!!! What do i have to do. I am using my Intake Manifold, My alternator, my dizzy, and everything else. But i have heard that the 97' Civic's have a crank position sensor and 94' SOHC VTEC's don't. If this is true, how do i bypass this. I need to know so any Honda boys out there that know your stuff this is where i need you guys the most.
Old May 11, 2006 | 07:50 PM
Default RE: ANOTHER BIG QUESTION
I was also wondering if i switch to an OBD1 ECU will i have to use this sensor?
Old May 11, 2006 | 08:50 PM
AgentofDarkness's Avatar
Both engines have a crankshaft position sensor. If you are in the United States, i do not think you can go back to OBD I from an OBD II engine. Also, there is a website that sells wiring harnesses but i'm not sure what the website is.
Old May 11, 2006 | 08:54 PM
Were is the cranks sensor located on the D16Z6 and will my Y8 harness plug in or will i have to cut a solder?
Old May 12, 2006 | 05:27 AM
Old May 12, 2006 | 03:58 PM
Nail I3unny's Avatar
well youc an go back to OBDI but its probably more work than its worth in america.
Newbie2000ex
Nov 21, 2011 02:06 PM
liquid_force3
Aug 31, 2009 08:18 PM
civic96lx
Jun 25, 2007 06:55 AM
cornerblitz59
Jul 29, 2006 11:21 PM
F23AccordLX
May 3, 2006 02:40 PM
